Database of Case Studies Achieved Using CADP
Multilateral and RBAC Security for Management of Distributed Systems
Organisation: Laboratório de Redes e Gerência, Universidade Federal de Santa Catarina (BRAZIL)
Method: LOTOS
Tools used: CADP (Construction and Analysis of Distributed Processes)
Domain: System Security.
Period: 2005
Description: Role-based access control (RBAC) is a mechanism for controlling access to files and other resources in a computer system by assigning roles to users, rather than assigning users with particular access rights or privileges. RBAC is increasingly used in complex distributed systems, because it reduces the complexity of user access management.
This case study concerns a real-time accounting system with multiple users and multiple suppliers, where both the Multilateral Security and RBAC models are applied. The system was specified in LOTOS and the CAESAR compiler of CADP was used to create the Labelled Transition System (LTS) of the specification in BCG format, for visual inspection and validation purposes. A prototype application was also developed.
Conclusions: This case study presents a typical workflow for using CADP to verify a LOTOS specification for an application that is relatively simple but of critical importance.
Publications: [Alvarez-Westphall-Westphall-05] Luis Marco Cáceres Alvarez, Carlos Becker Westphall, and Carla Merkle Westphall. "Segurança Multilateral e RBAC para Gerência de Contabilidade em Sistemas Distribuídos". V Simpósio Brasileiro em Segurança da Informação e de Sistemas Computacionais (Brazilian symposium on information and computer systems security), 216-230, 2005, in Portuguese.
Available on-line at: http://labcom.inf.ufrgs.br/ceseg/anais/2005/artigos/12417.pdf
or from the VASY FTP site in PDF or PostScript
Contact:
Caixa Postal 476
Florianópolis
SC
Brazil
Email: caceres@lrg.ufsc.br
Further remarks: This case-study, amongst others, is described on the CADP Web Page: http://cadp.inria.fr
Last modified: Wed Sep 21 15:11:02 2011.
Back to the CADP case studies page
