| Organisation: |
CWI, Vrije Universiteit, Universiteit van Amsterdam,
and Technische Universiteit Eindhoven (The Netherlands)
| Method: |
Tscript
mCRL2 |
| Tools used: |
CADP (Construction and Analysis of Distributed Processes)
mCRL2 |
| Domain: |
Coordination.
| Period: |
2008.
n/a
| Description: |
ToolBus provides a simple, service-oriented view on how to organize
software systems by separating the coordination of software components
from the actual computation that they perform. ToolBus organizes a
system along the lines of a programmable software bus. A system is
programmed using the scripting language Tscript, based on the process
algebra ACP (Algebra of Communicating Processes) and abstract data
types. The tools connected to the ToolBus can be written in any
language and can run on different machines.
A Tscript program can be tested, like any other software system, to
observe whether it exhibits the desired behavior. An alternative
approach for analyzing communication protocols is model checking, which
constitutes an automated check of whether some behavioral property is
satisfied. This can be, roughly, a safety property, which must be
satisfied throughout any run of the system, or a liveness property,
which should eventually be satisfied in any run of the system. To
achieve this, a Tscript program is first translated into a mCRL2
specification, from which the labeled transition system (LTS) is
generated. Then, correctness properties are checked on this LTS using
either mCRL2 or CADP. This approach has been applied on a standard
example from the ToolBus distribution: a distributed auction system.
| Conclusions: |
The general aim of this work is to have a process algebra-based
software development environment where both formal verification and
production of an executable system is possible. The translation scheme
from Tscript to mCRL2 makes it possible to apply formal verification
techniques to Tscript, and thus to check behavioral properties of large
software systems that have been built with the ToolBus.
| Publications: |
[Fokkink-Klint-Lisser-Usenko-08]
Wan Fokkink, Paul Klint, Bert Lisser and Yaroslav S. Usenko.
"Towards Formal Verification of ToolBus Scripts". Proceedings of the
12th international conference on Algebraic Methodology and Software
Technology, pp.160-166, Springer-Verlag, July 2008.
Available on-line at: http://www.cs.vu.nl/~wanf/pubs/amast08.pdf or from the VASY FTP site in PDF
or
PostScript
[Fokkink-Klint-Lisser-Usenko-10] Wan Fokkink, Paul Klint, Bert Lisser and Yaroslav S. Usenko. "Automated Translation and Analysis of a ToolBus Script for Auctions". Lecture Notes in Computer Science, Fundamentals of Software Engineering, pages 308-323, Springer-Verlag, 2010, Volume 5961. Available on line at: http://www.springerlink.com/content/9040068v35248m84/ or from the VASY FTP site in PDF
or
PostScript
| Contact: | Wan Fokkink Vrije Universiteit Amsterdam Department of Computer Science Section Theoretical Computer Science De Boelelaan 1081a 1081 HV Amsterdam The Netherlands Tel: +31 20 598 7735 Fax: +31 20 598 7653 Email: wanf@cs.vu.nl |
| Further remarks: | This case-study, amongst others, is described on the CADP Web Page : http://cadp.inria.fr |
