Database of Case Studies Achieved Using CADP
Equipment Failure Management Protocol
Organisation: INRIA Grenoble Rhône-Alpes (FRANCE)
Method: SAM, LOTOS NT, temporal logic
Tools used: CADP (Construction and Analysis of Distributed Processes)
Domain: Embedded Systems for Avionics.
Period: 2009
Size: 4,000 lines of LOTOS NT
Description: This study was done in the framework of the TOPCASED project. The object of the study was a proprietary protocol, which aims at managing equipment failures on airplanes. This protocol was specified as two automata described in SAM, a graphical synchronous language developed by AIRBUS.
A methodology developed for a previous avionics case-study was applied to this example: The two SAM automata modelling the protocol were translated into a set of LOTOS NT types and functions with boolean inputs/outputs (about 2,000 lines of LOTOS NT code). This step was made fully automatic by developing an ACCELEO plugin that implements this translation within ECLIPSE.
Additional LOTOS NT code (about 2,000 lines) was written manually to model: (1) the two "wrapper" processes encapsulating the LOTOS NT functions generated from the SAM automata; (2) extra protocol functionality not specified in the original SAM automaton; (3) bounded FIFO queues connecting the different parts of the system; and (4) the expected behaviour of the system's environment.
Then, the LOTOS NT specification was analyzed using the CADP tools: step-by-step simulation, generation of state spaces (about 100,000 states for a FIFO of length 3), equivalence checking and model checking of various properties expressed in temporal logic regarding, e.g., the activation/expiration of timers and the correct restransmission of requests on timeouts. This analysis enabled the detection of errors in the SAM specification. After correction of these errors, the protocol specification was proven equivalent to a model of the expected service.
A SAM automaton in a TOPCASED editor
Conclusions: This case-study constitutes an example of a simple and elegant approach, in which CADP plays a central role, for modelling and analysing GALS (Globally Asynchronous, Locally Synchronous) systems in the hardware design community.
Contact:
INRIA/VASY project-team
655, avenue de l'Europe
Montbonnot
38334 St Ismier Cedex
FRANCE
Fax: +33 476 61 52 00
Email: cadp@inria.fr
Further remarks: This case-study, amongst others, is described on the CADP Web Page: http://cadp.inria.fr
Last modified: Wed Nov 23 16:25:54 2011.
Back to the CADP case studies page
