Organisation: |
IRT Saint Exupéry, Toulouse
and
INRIA Grenoble / CONVECS team (FRANCE)
Method: |
LNT
MCL |
Tools used: |
CADP (Construction and Analysis of Distributed Processes)
Domain: |
Hardware Design.
Period: |
2020
n/a
Description: |
Multi-core platforms are suitable for the implementation of critical
real-time systems as they provide the computational power required by
embedded applications while maintaining an acceptable energy
consumption. However, the correctness of hard real-time systems
implemented on multi-core platforms is difficult to establish, since it
depends both on the correctness of the computations and on the
compliance with various temporal constraints (sampling time, worst-case
response times, data aging, etc.). Given that hardware resources are
shared between cores, estimating the Worst-Case Execution Times (WCET)
of tasks deployed on multiple cores is challenging, since the execution
of a task on a core may impact the timing behavior of the tasks
executing in parallel on other cores. Therefore, a reasonable WCET
estimation requires to identify the sources of such interferences and
take their effects into account.
This work proposes a method to automate the detection of temporal interferences (i.e., situations where the execution time of a task changes due to the presence of other tasks running on other cores) using formal methods and verification. The first step is to build two behavioural models of the software application and execution platform in the LNT language: an isolated model (with only one core enabled, and thus interference-free) and a non-isolated model (with all cores enabled, and thus containing interferences). The interferences manifest as differences between the execution traces generated from these two behavioral models. Two solutions are proposed to detect these differences: PATCHECK defines interferences as specific trace patterns, describes them in the MCL language, and uses the model checker of CADP to detect their presence on traces generated from the non-isolated model; SYNCHECK compares the traces obtained from the isolated and non-isolated models by computing a specific synchronous product using the EXP.OPEN tool of CADP and checking an MCL formula denoting the presence of interferences in this product. This method was applied to a part of Infineon’s AURIX TC275 microcontroller, a System-on-Chip (SoC) containing three in-order execution cores equipped with private local memories for program and data. Each core has two memory interfaces: a Program Memory Interface (PMI) and a Data Memory Interface (DMI). The SoC’s components (cores, memories, IPs) are interconnected via the Shared Resource Interconnection Crossbar Interconnect (XBar SRI) and the System Peripheral Bus (SPB). The interference detection method was successfully applied on several synthetic applications and also on an Integrated Air System Control (IASC) running on AURIX TC275. |
Conclusions: |
The detection of interferences in real-time applications running on
multicore systems can be (partly) automated using behavioral modeling
and verification using LNT, MCL, and CADP. The application of the
proposed method to a part of the AURIX TC275 platform has shown that
the analysis is both safe and able to prevent reporting spurious
interferences.
Publications: |
[Nguyen-Jenn-Serwe-et-al-20]
Viet Anh Nguyen, Eric Jenn, Wendelin Serwe, Frédéric
Lang, and Radu Mateescu.
Using Model Checking to Identify Timing Interferences on Multicore
Processors. Proceedings of the 10th European Congress on Embedded Real
Time Software and Systems (ERTS'2020), Toulouse, France, January 29-31,
2020.
Available on-line at: https://hal.inria.fr/hal-02462085/en or from the CADP Web site in PDF or PostScript |
Contact: | Eric Jenn IRT Saint Exupéry B 612 3 rue Tarfaya, CS 34436 F-31405 Toulouse FRANCE Email: eric.jenn@irt-saintexupery.com |
Further remarks: | This case-study, amongst others, is described on the CADP Web site: http://cadp.inria.fr/case-studies |
