| Organisation: |
University of Stirling (SCOTLAND, UNITED KINGDOM)
| Method: |
LOTOS
| Tools used: |
CADP (Construction and Analysis of Distributed Processes)
TestGen |
| Domain: |
Radiotherapy Equipment.
| Period: |
2002.
910 lines of LOTOS, 180 of which are generated from the constraint
annotations
41,097 states and 62,224 transitions 520 states and 546 transitions (after minimization with respect to observational equivalence) 256 test cases |
| Description: |
Linear accelerators, which accelerate a beam of electrons to
high-energy for use as X-rays, play an important role in cancer
therapy. Their correct function is safety-critical and demands
accurate delivery of radiation, usually used to destroy cancerous
tissue: a radiation underdose is as undesirable as an overdose, since
it might fail to kill a tumor, and not delivering radiation to the
exact area damages surrounding healthy tissue.
In contrary to early radiotherapy equipment, modern accelerators are complex-software controlled systems. Like for any application, the manufacturer upgrades the accelerator software from time to time. Thus it is desirable to check that the new version has not introduced any flaws. This case study describes the use of the conformance testing approach, originally developed for protocol verification, to the testing of radiotherapy accelerators. The suggested approach proceeds in several steps. Based on an understanding of the application via discussion with radiotherapy experts, an informal model of the system is created, and refined to a formal LOTOS specification, which is then annotated with constraints (significant test values and orderings of events). These constraints are translated automatically to LOTOS and integrated in the formal LOTOS specification. Using CADP, the labelled transition system corresponding to the specificiation including the constraints is generated and minimized. By traversing the generated labelled transition system, a suite of tests is generated automatically, and run against the implementation to decide whether it conforms to its specification. |
| Conclusions: |
LOTOS is an appropriate language for the specification of radiotherapy
accelerators, ties well with theories for test generation, and is well
supported by readily available tools.
| Publications: |
[Turner-Bing-02]
Kenneth J. Turner and Qian Bing.
"Protocol Techniques for Testing Radiotherapy Accelerators". In
Proceedings of the 22nd IFIP WG 6.1 International Conference on
Formal Techniques for Networked and Distributed Systems FORTE'2002
(Houston, Texas, USA), 2002.
Available on-line at: http://www.cs.stir.ac.uk/~kjt/research/pdf/test-rad.pdf or from the VASY FTP site in PDF
or
PostScript
[Turner-05-a] Kenneth J. Turner. "Test Generation for Radiotherapy Accelerators". In Springer International Journal on Software Tools for Technology Transfer (STTT), volume 7, number 4, August, 2005. Available on-line at: http://www.cs.stir.ac.uk/~kjt/research/pdf/test-gen.pdf or from the VASY FTP site in PDF
or
PostScript
| Contact: | Prof. Kenneth J. Turner Computing Science and Mathematics Room 4B78 University of Stirling Stirling FK9 4LA Scotland, United Kingdom Tel: +44-1786-467-423 Fax: +44-1786-464-551 Web: http://www.cs.stir.ac.uk/~kjt |
| Further remarks: | This case-study, amongst others, is described on the CADP Web Page : http://cadp.inria.fr |
